rate limit with no burst
lkadlik
I am running IOS  c7200-p-mz.123-20.bin and want to hard set bandwidth on an interface to 10 MB. Is it possible to do to this using the rate-limit command? If so, how?  If not how can I achieve this?
rate-limit input 10000000 X X conform-action transmit exceed-action drop
rate-limit output 10000000 X X conform-action transmit exceed-action drop
What would the "X" values be if it is possible to use the above command?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, rate-limit (or a policier) could be one way to accomplish limiting bandwidth to a certain value, but without adjusting
For burst sizes, perhaps about half your bandwidth delay product.
singhaam007
Level 3
Level 3
hello,
your xxx represets burst traffic parameters.
If you limit traffic is to 10 Mbps, with a normal burst size of 1,500,000 bytes. Traffic that does not conform is dropped. You can create burst how much you want. Its just if user reach 10 Mb limit then he/she can use burst traffic in the congestion. If you do not want any bust to be configured then use normal exceed-action drop.
See the following command in the example:
rate-limit input 10000000 1500000 exceed-action drop
http://www.cisco.com/en/US/docs/ios/12_2/qos/command/reference/qrfcmd8.html#wp1037428
there is another way to do rate limit by using plicy map.
ip access-list extended ACL_SLAP
permit ip any any
class-map match-all CLASS_SLAP
  match access-group name ACL_SLAP
policy-map POLICY_SLAP
  class CLASS_SLAP
    police 10000000 100000 exceed-action drop
interface GigabitEthernet0/2
service-policy input POLICY_SLAP
hope this will help.
thanks
