06-22-2013 02:16 AM - edited 03-07-2019 02:01 PM
hi,
could you plezse tel me who i can set rate limite on interface giga etheernet 0/0/X.
best regard.
06-22-2013 04:38 AM
Hello
You don't say what make/model of router/switch you have also if you just want to rate limit all traffic or define a type of traffic class.
You can either apply a class based policer or shaper to obtain rate limitation.
Depending of the above you can police from your in coming LAN traffic prior to it going out onto the wan interface or shape on the wan interface.
Policing to 10mb:
Policy-map Police All-traffic
Class class-default
Police 10000000 312500 exceed transform-set drop
Int xxx( LAN facing)
Service-policy input Police-All-traffic
Shape to 10mb:
Policy-map Shape-All-traffic
Class class-default
Shape average 10000000
Int gig x/x
Service-policy output Shape-All-traffic
But as I have stated you haven't provided enough information to verify the above examples
Res
Paul
06-22-2013 05:19 AM
Hi sir ,
i have already set a polcy map:
policy-map Voip-policy #
class Voip #
priority percent 75 #
but i want to migrate this config to a new router that he contains a different interfaces:
old config: serial interface router's:
interface Serial3/0
ip address XXXXXXXXXX XXXXXXXXX
rate-limit output access-group 102 64000 8000 8000 conform-action transmit exceed-action drop
new gigaethernet interface router's:
interface GigabitEthernet 0/0/2
service_policy output voip-policy
Best regards
06-22-2013 05:28 AM
FYI:
IOS XE Version: 03.07.00.S
Bootflash:/asr1001-universalk9.03.07.00.S.152-4.S.bin
