Showing results forĀ
Search instead forĀ
Did you mean:Ā
RE:EIGRP ROUTING
dinesh.basam
i configured EIGRP between two 4506E switces,st
p and hsrp is working fine.but i am getting the err
or messages shown below
Feb  8 06:50:01 GMT: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(355) 355: Neighbor 10.224.2
04.9 (Vlan150) is up: new adjacency
*Feb  8 06:50:19 GMT: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(355) 355: Neighbor 10.224.2
04.25 (Vlan250) is down: interface down
*Feb  8 06:50:19 GMT: %PIM-5-NBRCHG: neighbor 10.224.204.25 DOWN on interface Vl
an250 non DR
*Feb  8 06:50:20 GMT: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(355) 355: Neighbor 10.224.2
04.9 (Vlan150) is down: interface down
*Feb  8 06:50:20 GMT: %PIM-5-NBRCHG: neighbor 10.224.204.9 DOWN on interface Vla
n150 non DR
*Feb  8 06:50:22 GMT: %PIM-5-NBRCHG: neighbor 10.224.204.9 UP on interface Vlan1
50
*Feb  8 06:50:22 GMT: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.224.20
4.9 on interface Vlan150
*Feb  8 06:50:22 GMT: %PIM-5-NBRCHG: neighbor 10.224.204.25 UP on interface Vlan
250
4.25 on interface Vlan250
*Feb  8 06:50:26 GMT: %PIM-5-NBRCHG: neighbor 10.224.204.9 DOWN on interface Vla
n150 non DR
Amit Singh
What does " show log " reveals? Does it show the link  flapping.If the link is not flapping , there is some communiction problem between the two chassis.
It looks like that this may be the cabling issues. Have you tried swapping the cable?
Cheers,
-amit singh
If you can post your EIGRP config that would be helpful.
Mike
