Re: Q on Configuring an Access_Switch ...
InternetB
My question is that I am setting up a 3750 access switch. My management vlan is vlan 1 and I have one data vlan which is vlan 2. The default-gateway is the interface vlan ip of vlan 2
which is created on the distribution router.
Here is the config for this basic setup :-
-----------------------------------------3750 Access Switch
vlan 1
name Mgmt_Vlan
vlan 2
name Data_Vlan
int Vlan1
description *** Management Vlan ***
ip add 139.200.1.40 255.255.255.0
ip default-gateway 139.200.2.251 <<<<<<<<
My question is would the above setup okay or do I need to change it to the ip of the interface vlan 1 on the distribution router ?
It should work but I would just like to double confirm this simple setup.
Thank you,
Cheers,
- InternetB -
glen.grant
It should be the router address for vlan 1 . If using a default gateway make sure routing is turned off on the 3750 .
Hello Glen,
[1] Thank you for the post. The reason that the 3750 needs its gateway pointing to the interface of vlan 1 is because the SVI on the 3750 is on vlan 1/ same IP subnet ?
Just want to understand the logic.
Thank you,
Cheers,
- InternetB -
"The reason that the 3750 needs its gateway pointing to the interface of vlan 1 is because the SVI on the 3750 is on vlan 1/ same IP subnet ? "
Yes because the 3750 is only acting as a L2 device you can only have vlan interface in use and that should be for management. So this vlan 1 interface is used purely to gain access to the switch and not for any user data. The default-gateway is needed so you can remotely telnet into the switch.
Note as a side issue Cisco recommends using a vlan other than vlan 1 for managing your switches. It's not vital so don't worry, it's just best practice.
Jon
