09-22-2013 05:43 AM - edited 03-07-2019 03:36 PM
Hi All,
Right now I'm using 2 cisco switches (redundant). The model for those switches is Catalyst SW-2960G-24TCL.
I'm planning to add more servers to the current network but all the ports in the two switches are occupied.
Could you please recommend a new switch with 16 ports which has similar features to the above switches, and what you think the best design will be?
09-22-2013 08:10 AM
The smalls switches are mostly 24 port or 48 ports. There is 3560 8 ports but may not be good enough for servers. So, just get another SW-2960G-24TCL 24 port switch. This way, you are using the same IOS for all switches which makes life easier.
09-22-2013 02:55 PM
Before doing anything, check your interface counters and make sure you don't have anything under "Total output drops".
If this counter increments periodically, then there's a significant chance your switch's buffer is unable to cope at the continuous traffic (inbound and outbound) from your servers.
