07-09-2013 05:49 PM - edited 03-07-2019 02:19 PM
Hi Guys,
Can I please have a recommendation on the most stable release of IOS to use for Cat 3750 and 2960 switches.
The 3750s will be stacked.
The 2960s will be used for DMZ switching.
Nick.
07-09-2013 05:54 PM
Quick and Easy Answer:
3750/3600 series:-I recommend a "stable" IOS, then 12.2(55)SE7 . This is followed by 15.0(2)SE2(If you required 802.1x support) else 12.2(55)SE7 is the best.
2900:- 15.0(2)SE2 works well with 2960/G/S even with 802.1x.
Hope this answered your query.
Inayath
********Plz rate all usefull posts.
07-09-2013 06:43 PM
3560/3750: If you are using 802.1X & Layer 3, use 12.2(55)SE7. If you are not, then 15.0(2)SE2 is OK for LAYER 2.
2960: 15.02(2)SE2 is a good release.
Currently testing 12.2(55)SE8 and 15.0(2)SE4. So far so good. Will let you know in 10 days time how it goes.
08-12-2013 11:11 AM
is 12.2(55)SE8 stable for C2960S? How is the test result?
Thanks!
08-12-2013 06:20 PM
Yes it looks okay as of now. So you can plan for the upgrade of the same.
Inayath
******Please rate useful posts and remember to mark any solved questions as answered. Thank you.
08-19-2013 05:52 AM
upgraded to 12.2(55)SE8 last week on the 2960S stack.
It crashed again this morning: Which IOS version is more stable? Will it be hardware related? Thanks!
Aug 19 07:33:00.083: %PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 37, class 14, max_msg 32, total throttled 2892 (CRKS-SW2-2)
-Traceback= 13C85F4 162F870 16352E0 1609354 1878288 186ED00 (CRKS-SW2-2)
Aug 19 07:34:00.188: %PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 37, class 14, max_msg 32, total throttled 2904 (CRKS-SW2-2)
Aug 19 07:35:00.308: %PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 37, class 14, max_msg 32, total throttled 2916 (CRKS-SW2-2)
Aug 19 07:36:00.439: %PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 37, class 14, max_msg 32, total throttled 2928 (CRKS-SW2-2)
08-19-2013 04:33 PM
If it's crashed, then there should be a crashinfo file(s).
Create a new thread and attach the file(s).
08-19-2013 08:43 PM
you need: no snmp-server ifindex persist
if you not have this command you need to contact the TAC:
Error Message PLATFORM_RPC-3-MSG_THROTTL
