Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi All , I am in the testing phase of migrating to a 9300. So far I have done the below.3850 running 16.3.6   and 9300 updated 17.09.04aI have copied the start-up config to the 9300 - all looks ok apart from the usual ip routes , some interfaces not ...
machine23 by Level 1
  • 93 Views
  • 2 replies
Hi everyone, I have a Cisco catalyst C1200-24P-4X switch, and I want to enable stacked VLAN configuration on it. Does it can support the feature?
moges1 by Level 1
  • 104 Views
  • 1 replies
Hello, CML (Cisco Modelling Lab) 2.5 announced a virtual Catalyst 9000 running IOS-XE 17.10 - I tested this out on my personal CML 2.6.1 and I am struggling to get 802.1X working. I know Cat 9K virtual is still a beta release and the CML folks can't ...
I am configuring a DHCP Server for a small VLAN.I have configured vlan 10 20 30 and trunk access for switch interfaces, activated fa0/0.1, fa0/0.2, fa0/0.3 as example belowint fa0/0.1 encapsulation dot1Q 10 ip address 192.168.10.1 255.255.255.0 ip he...
Hello forum! We're working on a migration from voice service to webex and the team handling that has requested i find the LLDP chassis mac address and port Id. I'm trying to do this in the cli and the sh mac-address-table command shows a myriad of ad...
Preadyth by Level 1
  • 150 Views
  • 4 replies
  • 1 Helpful votes
hi friendsi config below commands to configure AAA authenticate with Microsoft Active Directory 2008(CIsco Device Integrate with AD microsoft for telnet and ssh and both can login to console by AD and local username) but while i unplugged Cisco Devic...
zavira123 by Level 1
  • 53403 Views
  • 7 replies
  • 1 Helpful votes
Good morning, On a Switch C2960X-24TD-L (UNIVERSALK9-M)(Boot loader C2960X), following a configuration error, I can no longer access the console in privilege mode.The only account available only allows me to access in user mode.I can't make any write...
Christory by Level 1
  • 189 Views
  • 5 replies
I have a couple of switches that are trunked via a LAN cable from another switch. I noticed that these switches sometimes have a hard time to SSH into. I get the error: "Connection timed out". After a while and a few tries I can connect just fine. I ...
Rick001 by Level 1
  • 128 Views
  • 3 replies
