09-07-2015 09:08 AM - edited 03-08-2019 01:40 AM
we are using DHCP in Cisco 3750 Switch
10.100.96.0/22
dhcp excluded ip 10.100.96.1 10.100.96.100
100 IP excluded from DHCP
But after some ip leased .
excluded ip is keep on increasing like 110,120,140 so on.
Pls find the attachment for reference
09-07-2015 01:03 PM
I do not understand the relationship between the picture that you posted and the text description of the problem. The picture seems to show a stable environment which has not changed, but the text talks about things changing. Perhaps you can clarify?
It might help us understand what is going on if you would post the config of the 3750.
Rick
09-07-2015 10:08 PM
Dear Rick
Pls find the config and attachement
Building configuration...
Current configuration : 4689 bytes
! Last configuration change at 05:30:03 UTC Wed Mar 30 2011
! NVRAM config last updated at 05:03:32 UTC Mon Sep 7 2015
version 15.0
no service pad
hostname C3750x-IDF-MDF
boot-start-marker
boot-end-marker
no logging console
enable secret 4 xUXmaOYEUzaXX0sbaQulbzYHEYR/GFgqVAhf75NlA/M
no aaa new-model
clock timezone UTC 4 0
clock save interval 8
switch 1 provision ws-c3750x-12s
system mtu routing 1500
ip dhcp excluded-address 10.100.95.1 10.100.95.50
ip dhcp excluded-address 10.100.96.1 10.100.96.100
ip dhcp excluded-address 10.100.100.1 10.100.100.50
ip dhcp excluded-address 10.100.92.1 10.100.92.50
ip dhcp excluded-address 10.100.94.1 10.100.94.50
ip dhcp pool Wifi
network 10.100.96.0 255.255.252.0
dns-server 213.42.20.20
default-router 10.100.96.1
domain-name Al-Asayl-Wifi
lease 0 8
update arp
ip dhcp pool cctv
network 10.100.100.0 255.255.255.0
default-router 10.100.100.1
domain-name Al-Asayl-CCTV
lease 0 8
update arp
ip dhcp pool Data
network 10.100.92.0 255.255.254.0
dns-server 213.42.20.20 195.229.241.222
default-router 10.100.92.1
domain-name Al-Asayl-Data
lease 0 8
update arp
ip dhcp pool Voice
network 10.100.94.0 255.255.254.0
default-router 10.100.94.1
domain-name Al-Asayl-Voice
lease 0 8
update arp
ip dhcp snooping vlan 1,10-11,21,31,99-100
ip dhcp snooping
crypto pki trustpoint TP-self-signed-3005141760
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3005141760
revocation-check none
rsakeypair TP-self-signed-3005141760
crypto pki certificate chain TP-self-signed-3005141760
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33303035 31343137 3630301E 170D3131 30333330 30313239
32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30303531
34313736 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B175 AD218997 73B9533C 795A7818 E5A93179 70175849 9E235EFD 0018E0E7
0561085F 20827636 40FA8242 87D53FCB D8FAC0B0 BA566343 04D95E54 E2CB49CC
8949E695 11BF46F6 F97BC3E9 009BCF61 69B3A675 F7CAB4F6 4C59ED8E 9A16F395
AC2D66FA C489AEF5 7EE5E08E 8880A662 E7BB99E1 4D2EC8F2 84DB2DD3 7BE6BDDE
DB870203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 144EF5A2 C7B0E524 D6647D95 098CDAD0 98C6C479 F8301D06
03551D0E 04160414 4EF5A2C7 B0E524D6 647D9509 8CDAD098 C6C479F8 300D0609
2A864886 F70D0101 05050003 8181001C 138BCE3D E6617D2A FE379508 D96DD43B
8DFA462F C86C446D 5CFB02A7 D4F4CE55 DCEFC38E 3600D671 B897F08D 79B32083
DE3ED3D1 038A2088 10438596 B27A0DCE 4DE1EE75 554396AD 9C5D5302 81AFAEF6
AE5FAC93 76185757 2279F9DD 01693821 86550D47 52E67502 52718A0F A1D9A28E
8ADDD98B 6B9CBDF8 4012B4B9 71DA6D
quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
switchport trunk allowed vlan 1,10,11,21,31,99,100
switchport mode trunk
ip dhcp snooping trust
interface GigabitEthernet1/0/12
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
ip helper-address 10.10.10.5
interface Vlan99
ip address 10.10.10.5 255.255.255.0
interface Vlan100
description Management IP Address
ip address 10.100.90.6 255.255.254.0
ip default-gateway 10.100.90.1
ip http server
ip http secure-server
09-08-2015 06:26 AM
Thank you for the additional information. Am I correct in understanding that this switch is operating as a layer 2 switch (no layer 3 processing) and that it is providing the DHCP service for devices that are remote?
Rick
09-08-2015 06:34 AM
Yes . This switch providing just DHCP Services. No other Layer 3 Operation.
