remove a module in VSS
Peter Haug
We have a Cat6800XL VSS and I tried to remove a module from the configuration. I know the command "module clear-config" but this does not work in VSS.
How do I remove this module in VSS?
Furose M
Level 3
Level 3
hey PEter,
the "module clear-config" command is not supported in VSS.
 Remove the modules from slot no X
*         Under 'module provision switch #', apply 'no slot X'.
Module provision switch 2
  No slot 3
*         Save the configuration and reload the entire VSS.
