Replacing 6509 with 9400 but still want to use 6509 for wireless controllers.
ArshdeepDhillon
Beginner
Beginner
I am going to replace my core which is 6509 with 9400 switch. But we have wireless controller on 6509 which I still want to use for sometime. So if I remove routing from 6509 and make a access switch would wireless controllers still work?
Thank you!
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
It depend on your current design. Is the current 6509 layer-3? Is the current 6509 a core switch or acting as an access switch?
Yes it is layer 3 and acting as core.
Than as long as you run layer-3 on the 9400, you should be able to use the wireless controller the same way as the old 6500.
9400 will be new core but I still want to use old 6509 just for wireless cards as they wont work in new chassis. Should I just remove routing from old core and make it access switch and wireless blades on it will still work?
Recognize Your Peers
