restricting rip route adverts
mburguk1000
Level 3
Level 3
I have just enable rip on a network layer 3 switch and it picked up routes I didnt want listed.
Is there a command to restrict routes being advertised
mahmoodmkl
Level 11
Level 11
HI
I think u can go ahead with passive-interface command under u r interface from which u dnot want routes to be advertised.
Mahmood
you can also use distribute list which is similar to access lists to block routing updates
Deepak
