Highlighted
Beginner
Retrieve SFP model number Cisco 3750
Dear all,
I have a WS-C3750G-24TS network switch with one SFP module installed. The show inventory raw command displayes the following;
NAME: "GigabitEthernet1/0/25", DESCR: "1000BaseSX SFP"
PID: , VID: 255, SN: FNS0928G0FE
SW61#sh interface gigabitEthernet 1/0/25 capabilities
  Model:                 WS-C3750G-24TS
  Type:                  1000BaseSX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),tx-(4q2t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
  Speed:                 1000
  Duplex:                full
  Channel:               yes
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  PortSecure:            yes
  Dot1x:                 yes
How can I know if the SFP supports Multi Mode (MM) or Single Mode(SM) or is there a way to retrieve the SFP model somehow?
Best regards,
Wim
1 REPLY 1
Highlighted
VIP Mentor
Re: Retrieve SFP model number Cisco 3750
You can find it by looking at the description of the SFP module in this output.
SX - Short Wavelength ( ie Multi Mode module)
LX - Long Wavelength (ie Single Mode module)
In your case it appear as below which indicating it is MM SFP module.
"DESCR: "1000BaseSX SFP"
Here  is some reference to this (old but still valid)
http://www.cisco.com/en/US/tech/tk389/tk214/tech_brief09186a0080091a8a.html
Rasika
**** Pls rate all useful responses ****
Content for Community-Ad
