03-31-2019 09:35 AM
Hi all,
how can I do the following in terms of port/VLAN management and configuration:
Solved! Go to Solution.
03-31-2019 10:21 AM
You should be able to put both the TV and the PC you want to stream within in the same vlan or whatever default vlan that comes with the switch. This way, it is all part of the same LAN filed and there is no need for multiple vlans, routing, etc..
03-31-2019 10:21 AM
