Rip 1 Across Differents Vlans
Mauro Rovedo
Hello ! I've got headache to try to solve a lab .
The situation include 2 cisco routers an 2 switch 3550
so we have  Router A  in Vlan x access ----->Sw1----Trunk----Sw2<------Vlan y Access Router B
I 've to enable rip1 on guys A and B ONLY !!! Avoiding any kind of tunnel
I though it was all around fallBAck bridging ... but after days of tries .... i dont have found any solution ...
May you have any kind of idea ?Better solution
Ty !
cadet alain
configure sw1-sw2 as access port in same vlan rtrA and sw2-sw1 as access port in same vlan as rtrB then under RIP process on each router configure no validate-update-source and it should work.
EDIT:  I tried it and the rip routes were propagated indeed but there is a recursive lookup problem due to ARP and it won't work even with static arp entries
so finally not a valid solution for your problem. Gonna think  it over and if I find something working without a tunnel I'll let you know
EDIT2:  configure ip mobile arp on both routers fastethernet then shut/no shut the interface and it iwill work, I've tried it on GNS3.
but I didn't use a trunk link between the 2 switches but configuring the other end access vlan as native vlan on each switch should do the trick with
the trunk link.
Regards.
Alain.
Halo Just updates the info about LAb
RTB SERVER DHCP PPPOE ------>FA/0 (172.16.100.1) both access vlan 100  BVi interface bridge
                                                      ------>FA/1
RTC Client DHCP PPPOE FA/0 Access VLan 100
Between those guys we SW1 ------ Trunk ------ Sw2
RTD SErver DHCP PPPOE ------- FA0/1 both access vlan 130  (172.16.130.1)  BVI interface bridge                                         --                                                      --                                                     --FA0/0
RTE Client DHCP PPPOE FA0/0 Access Vlan 130
At thi point i 've to configure w/0 any kind o tunnel a ripv1 session Between RTE And RTC....
BEing a point to point , when i do debug ip rip ...see ofc my dialer 1 send ip to BVI that discard it because it does not hase any FIB lookup ruting.
THis if i left rip in Broadcast ....if i dgt neighobor x.x.x.x it does not work anyway
Using no validate-update under rip process...also
ANy suggestion
Ty in advice ...
have you tried the solution I posted before because I tested it in GNS3 and it worked, it should even work without the mobile arp but just configuring static arp entries for each RIP router and shutting/no shutting the interfaces.
Regards.
Alain
