roaming on access points
carl_townshend
Hi all, which setting on my access point allows me to roam between them without getting cut off ?
fargier
It implicit with no authentication and if you have the same ssid.
If you use authentication eap-XXX you may have delay. But fast-roaming can help you.
Ludo
