02-06-2009 01:51 PM - edited 03-06-2019 03:54 AM
Dear Friends,
Has somebody worked on Role Based CLI in Catalyst 6500 switches?
I am working on a 6500 with IOS version 12.2(33)SXH3 IP Services version but i am not getting the options enable view or parser view.
Looking forward to your kind guidance on this.
02-06-2009 02:58 PM
If the command is not available, it is most likely not supported in SXH3.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtclivws.html
You can use "software advisor" to check if it is supported or not.
02-06-2009 10:18 PM
Thanks for the info. Its ok if its not supported. I just wanted to know if anyone knows of an alternative to Role based CLI in 6500
Thanks a lot
Gautam
02-06-2009 11:31 PM
AAA would be a nice alternative to role based cli
02-07-2009 10:07 AM
Thanks John. We are not going to integrate these devices with ACS.
So, i am looking at some local a/c privilege level command assigments.
Please do let me know of any link or idea that you can suggest in this case for the Cat 6500.
Thanks a lot
Gautam
