ROMMON Flash_Init not working
I have a Cisco 3650 that it booting into ROMMON.  In ROMMON, when I run dir I am only seeing these:
switch: dir
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
tftp[12]: (read-write)
usbflash0[13]: (read-write)
So I run flash_init and it seems to run successfully:
switch: flash_init
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
but if I run dir after the flash_init I still don't see flash:
switch: dir
List of filesystems currently registered:
bs[3]: (read-only)
I have the bin image on the usb drive and tried booting to that image but get the following:
switch: boot usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin
loading usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin
Reading full image into memory...read: premature eof
usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin: short read: bad mzip file
Error loading "usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
Any ideas on how I can get this up?
Thanks.
6 Replies 6
Giuseppe Larosa
Hello mcbrown,
try to boot using a TFTP server on your PC connected to the switch with a LAN cable.
follow the instructions on this document
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-1/configuration_guide/b_161_consolidated_3650_cg/b_161_consolidated_3650_cg_chapter_01101001.html?dtid=osscdc000283#task_1099467
Once you are able to boot with an IOS image you can try to format the flash: this might recover it or not.
Hope to help
Giuseppe
Leo Laohoo
Error message means the IOS file is corrupt.
Go to the Cisco website and download the firmware again.
IMPORTANT:  Make sure you compare the MD5 hash value of the file downloaded against the MD5 hash value found in the Cisco website.
And then read this:  Emergency Recovery
Hello Leo,
thanks for having seen the issue with the file image on the USB drive,
I admit I have missed it.
Best Regards
Giuseppe
We're all here to help. :)
Ok I downloaded the image again and tried booting from the USB and am getting this:
Reading full image into memory................................................................................................................................................................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address : 0x534516c8
Kernel Size : 0x368633/3573299
Initramfs Address : 0x537b9cfb
Initramfs Size : 0x19b53fb/26956795
Compression Format: mzip
Bootable image at @ ram:0x534516c8
Bootable image segment 0 address range [0x81100000, 0x81c14630] is in range [0x80180000, 0x90000000].
File "usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin" uncompressed and installed, entry point: 0x816e4ac0
Loading Linux kernel with entry point 0x816e4ac0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
sd 1:0:0:0: [sdb] Asking for cache data failed
ata1.00: cmd ca/00:08:00:00:08/00:00:00:00:00/e0 tag 0 dma 4096 out
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
ata1.00: status: { DRDY }
ata1: SRST failed (errno=-16)
? localhost
State: initializing
Jobs: 3806249 queued
Failed: 3806249 units
Since: Thu 1970-01-01 00:00:03 Universal; 49 years 7 months ago
CGroup: /
tqsystem.slice
x tqreport_fails.service
x x mq257 systemctl status -l -n 100 -o short-monotonic --no-pager
x tqsystemd-udevd.service
x x tq117 /lib/systemd/systemd-udevd
x x tq209 /lib/systemd/systemd-udevd
x x tq210 /lib/systemd/systemd-udevd
x x tq211 /lib/systemd/systemd-udevd
x x tq212 /lib/systemd/systemd-udevd
x x tq213 /lib/systemd/systemd-udevd
x x mq216 /lib/systemd/systemd-udevd
x tqsystem-check_partitions.slice
x x mqcheck_partitions@dev-bootflash.service
x x tq177 /bin/bash /bin/check_partitions.sh /dev/bootflash
x x mq188 sfdisk -uB -f /dev/bootflash
x mqsystemd-journald.service
x mq85 /lib/systemd/systemd-journald
mqinit.scope
mq1 /init splash SKIP_POST
>>> Rebooting
Failed to connect to bus: No such file or directory
ata1: reset failed, giving up
octeon_wdt: WDT device closed unexpectedly. WDT will not stop!
reboot: Restarting system
ààààààààààààààààààààààààààààààcf_identify_drive: cf_waitfor(!(BUSY | ERROR)): timed out.
Boot bus: Failed to detect any IDE storage!
flash:packages.conf: no such device
Cannot open file flash:packages.conf
The system is unable to boot automatically. The
BOOT environment variable needs to be set to a
bootable image.
Organize for an RMA.  The switch is dead.
