Route Filtering OSPF NEXUS
Hi Everyone,
I'm trying to filtering routes in a Nexus Device but i can't , this is the scenario:
Nexus 1 advertise routes: 10.0.0.1/32, 10.0.0.2/32, 10.0.0.3/32
Nexus 2 have to allow 10.0.0.1/32, 10.0.0.2/32 and deny 10.0.0.3/32
So i tried using a table-map
Prefix List:
ip prefix-list FILTRO-OSPF seq 10 permit 10.0.0.1/32
ip prefix-list FILTRO-OSPF seq 10 permit 10.0.0.2/32
Route map:
route-map FILTER-OSPF permit 10
     match ip address prefix-list FILTRO-OSPF
route-map FILTER-OSPF deny 20
OSPF
router ospf 100
table-map FILTER-OSPF filter
But after apply this, all routes al filtering, also i try with Filter-list but doesn't work
Please let me know if i'm doing something wrong
Patricio
7 Replies 7
balaji.bandi
not sure how your OSPF area, make sure Filter works :
FILTER LIST - Filters only LSA3, so - only on ABR, but filters from OSPF Database.
filter-list can be applied: IN - into the area, OUT - out of the area
BB
 This can be much more simple:
access-list 1 deny 10.0.0.3
access-list 1 permit any
router ospf x
 redistribute-list 1 in
I am considering intra-area, as you did not say this is a different area.
Hi Flavio,
Unfortunately that command is not supported in Nexus Devices.
Jon Marshall
Can you try using the reverse logic ie.
ip prefix-list FILTRO-OSPF seq 10 permit 10.0.0.3/32
route-map FILTER-OSPF deny 10
route-map FILTER-OSPF permit 20
Jon
@Jon Marshall yes thats way we need to do reverse way, but not sure if OP has that requirement for the rest all in for the prefxes.
BB
so it not support can you explain the topology may be we can find other solution.
Hello
try tweaking your route-map and prefix-list for the table-map
ip prefix-list FILTRO-OSPF permit 10.0.0.3/32
match interface x/x
route-map FILTER-OSPF permit 99
Additionally if your trying to negate Nexus 2 from advertising that host address, The below should negate type3 advertisement so assumption is Nk2 is an ABR
ip prefix-list FILTRO-OSPF deny 10.0.0.3/32
ip prefix-list FILTRO-OSPF permit 0.0.0.0/0 le 32
router ospf 100
area X filter-list prefix FILTRO-OSPF OUT
Kind Regards
Paul
