153
Beginner
Route Leaking (will routes bounce?)
I would like to route leak my VRF (vrf-a) into another VRF (vrf-b)
I have "production" routes in VRF-a that are learned by BGP and OSPF.
My question, when issue the import and export command will the existing routes be affected (i.e will BGP/OSPF be bounced?)
From memory, I am sure this causes some kind of routing hit but can't find any supporting documentaion.
Thank you for reading
Matt
1 REPLY 1
Contributor
Re:Route Leaking (will routes bounce?)
What platform and firmware are you on? Route leaking should not disrupt the BGP process since there isn't a neighbor to reset. It would only cause issues if you are changing VRF names or RDs. That has been my experience anyway. If you can't risk a disruption, make sure you make your changes during a maintenance window.
Mike
Sent from Cisco Technical Support Android App
Content for Community-Ad
July's Community Spotlight Awards
