Route-Map Issue in Cisco 6506 core switch
EZRA SHYAM
Beginner
Beginner
Hi All,
We have a scenario as below
Core1--> Core 2 --> Vendor Core
I have configured a VLAN in core-1( 172.16.1.0/24) and configured with route-map set with next-hop IP of vendor core switch ip (10.10.1.1).
I need an access to few destinations from Core-1 VLAN 172.16.1.0/24 to multiple destinations ( Ex: - 192.168.1.1, 10.5.2.10)which are reachable from 10.10.1.1
I have a routing from Core-1 to 10.10.1.1 but unable to access the destinations of 192.168.1.1 and 10.5.2.10  etc  by using set next-hop ip 10.10.1.1.
I can clear the issue by using static route to multiple destinations but I wanted avoid this.
So please support on available options to overcome this issue
Rrgs,
Ezra.
Jon Marshall
VIP Community Legend VIP Community Legend
Ezra
We need a few more details ie.
1) do you run HSRP/GLBP on core1 and core2 for vlan 172.16.1.x. If so which core switch is the active one ?
2) How are core1 and core2 interconnected ie. via L2 trunk or do they route to each other. If you do a "sh ip ro 10.10.1.1" what does it show ? ie.
is it directly connected or is it via a next hop on core 2 ?
3) can we see the route-map config + acl used in route-map
4) have you applied the route-map to the vlan 172.16.1.x interface ? Remember if core2 is active gateway you would need to apply it there as well.
Jon
HI Jon,
To add clarity just have drwan a rough topology diagram
172.16.1.0/24 has configured in R1 and R2,
1 Ans :- Core-1 (R1) and Core-2 (R3) are connected over fibre and with ospf then static routes redistributed to it.
2 Ans :-  10.10.1.1 is learning through OSPF
3.
route-map xxxx permit 10
match ip address 130
set ip next-hop 10.10.1.1
end
Conf t
Ip access-list ex 130
Permit ip 172.16.1.0 0.0.0.255 any
Conf t
Interface Vlan 30
ip policy route-map  xxxxx
exit
Revert for more info pls...
Rgds
On core1 what does "sh ip ro 10.1.1.1" show ?
set ip next-hop x.x.x.x  assumes that x.x.x.x is directly connected so is 10.1.1.x directly connected to core 1 ? If not then you can use "set ip next-hop recursive x.x.x.x" but i'm not sure whether that is supported on the switch. You can try it.
Jon
Hi Jon,
10.10.1.1. is learning through OSPF via Core-2
means from Core-1 2 hops away this 10.10.1.1 is rechable
And i have checked the recursive command but its not avilable in switches, I hope its meant for Routers
Please help
Rgds
Recognize Your Peers
