Router does not see Switch via sh CDP Neighbors
Shahzad Ayub
Router A ------------ Switch A -------------- Access Point 1 ------------ Access Point 2 -------------- Switch B ------------ Router B
Above is my topology design, two branches are connected through access points.Router A is able to ping Router B but they are not able to form neighbourship if I run any protocol and before that Router B even does not show switch B through CDP neigbour command.
Following is the configuration of Router B's interface connected to Switch B, access list on the router & nat commands.
interface FastEthernet0/1
ip address 78.93.41.217 255.255.255.248 secondary
ip address 192.168.17.10 255.255.255.0 secondary
ip address 192.168.1.10 255.255.255.0
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 10 permit 192.168.17.0 0.0.0.255
ip nat inside source list 10 pool no-overload overload
ip nat inside source static tcp 192.168.1.240 22 78.93.41.220 22 extendable
ip nat inside source static tcp 192.168.1.240 1300 78.93.41.220 1300 extendable
ip nat inside source static 192.168.1.2 78.93.41.221
configuration of Router A's interface connected to Switch A
ip address 192.168.1.229 255.255.255.0
duplex auto
speed auto
Can anybody please get me out of this problem.Thanks
mfurnival
Level 4
Level 4
I would not get too bogged down with CDP - you have said that the switches are managed so you can't definitely say that CDP is enabled on switch B. Bear in mind that when you form a routing protocol adjacency you may use either broadcast or multicast packets - so a ping may work but if you don't control the bit in the middle you can not be sure that all packets are passed. You could try creating a BGP relationship between the routers as this uses directed unicast. If that works then the issue is in the bit in the middle.
20 Replies 20
mfurnival
Level 4
Level 4
Can you confirm that you have CDP enabled on Switch B and Router B and that it is enabled on both interfaces?
What do you mean when you say "not able to form neighbourship" - are you talking about forming an adjacency with a routing protocol? If so which routing protocol and can we see the configuration of both routers please?
CDP is by default enable on routers & switches.
It means when i check with "sh cdp neighbor" on router B, it does not show switch B as its neighbor however i can ping from router B to Router A.
After that if I run any protocol both routers are unable to form adjacancy.It seems to be problem between Router B & Switch B.
It would really help if you could provide your configurations.
All your hardware is Cisco ? If the Access Point aren't Cisco CDP doesn't work, because CDP es a proprietary protocol. If this is the case Router_A can see Switch_A , and Router_B can see Switch_B but Switch_A can't see Switch_B.
You could check this : http://netcert.tripod.com/ccna/switches/cdp.html
Reggards.
I don't think he means that - he said that switch B can't see router B via CDP. I don't think he expects switch A to see switch B via CDP.
Hi Julio,
My point is that why Router B does not see Switch B in sh cdp neighbor command on router which is directly connected to it.
Hi mfurnival,
Here is the configuration of Router B:(fa0/1 of router B is directly connected to Switch B)
FAYHA-SC#sh running-config
Building configuration...
Current configuration : 5690 bytes
version 12.4
service password-encryption
hostname FAYHA-SC
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 ***********
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.40
ip dhcp excluded-address 192.168.1.230 192.168.1.254
ip dhcp excluded-address 192.168.1.229
ip dhcp excluded-address 192.168.1.224
ip dhcp pool 1
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.10
   dns-server 192.168.1.2 192.168.1.4
   lease 0 1
ip domain name yourdomain.com
ip name-server 84.22.224.11
ip name-server 84.22.224.12
archive
log config
hidekeys
interface Tunnel1
description tunnel to fayhaa1@512
ip address 172.26.1.130 255.255.255.252
tunnel source 192.168.221.106
tunnel destination 192.168.141.171
interface Tunnel3
description tunnel to fayhaa@512
ip address 172.26.3.130 255.255.255.252
tunnel destination 213.184.183.173
interface Tunnel4
ip address 172.26.4.130 255.255.255.252
tunnel destination 192.168.166.18
interface Tunnel5
description tunnel to fayhaa5@512
ip address 172.26.5.130 255.255.255.252
tunnel destination 78.93.14.169
interface Tunnel17
ip address 172.26.17.130 255.255.255.252
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.221.106 255.255.255.252
ip access-group 101 in
ip nat outside
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
ip nat inside
ip route-cache flow
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.221.105
ip route 10.68.20.0 255.255.255.0 Tunnel1
ip route 192.168.2.0 255.255.255.0 Tunnel1
ip route 192.168.3.0 255.255.255.0 Tunnel3
ip route 192.168.4.0 255.255.255.0 Tunnel4
ip route 192.168.4.0 255.255.255.0 192.168.1.252
ip route 192.168.10.0 255.255.255.0 192.168.1.252
ip route 192.168.11.0 255.255.255.0 192.168.1.252
ip route 192.168.12.0 255.255.255.0 192.168.1.252
ip route 192.168.14.0 255.255.255.0 Tunnel5
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool no-overload 78.93.41.218 78.93.41.220 netmask 255.255.255.248
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 101 deny   ip host 180.92.187.122 any
access-list 101 deny   ip host 50.31.129.129 any
access-list 101 deny   ip host 69.72.255.8 any
access-list 101 deny   ip host 128.63.2.53 any
access-list 101 deny   ip host 46.249.48.209 any
access-list 101 deny   ip host 72.20.38.18 any
access-list 101 deny   ip host 91.234.36.30 any
access-list 101 permit ip any any
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
password *******
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
I also tried OSPF on both sides but nothing was happening on both sides, no exhange of hellos even nothing was showing after i enabled debugging on both sides.I don't know what is the reason behind it.
is there any requirements of cdp neighbours to form adjuncy with routing protocol. Personally i dont think so.
Correct me if i am wrong.
Jawad
If you are able to ping bohat side routing protocal must go on
If its ISP involved you will have to coordinate with your Service provider also to run routing protocol
Jawad
Jawad
I agree CDP is not required; however l2 adjacency must be available, CDP is a good way of seeing that Layer 2 is working. as it'll show up even if someone has made a mistake and allocated the wrong ip address.
Can Switch B ping Router B? can switch B ping switch A? Can switch B ping router A?
Tony
Tony,
If you see toplogy Router B is reaching to Router A via Switch B and both routers are pinging to each other.Do you really think there can be issue with switch B?
I would like to mention that these switches are not manageable.
What type of switches are Switch A and B?
Tony
Are you sure they have CDP?
Jawad,
You did not get my point, I am trying to troublshoot this issue from the basics.As cdp is by default enabled on all devices and all devices are cisco devices then it should work in my scenerio......don't you agree????
I also mentioned that I also tried with OSPF but routers could not form adjacancy and they are not propagating anything even I enabled the debugging..........
i often had to turn on ''cdp run'' to enable cdp on both devices..however i too have a 2960S router connected to an asr1001x but despite having ''cdp run'' command issued i cant see the neighbors.
