Routing 3750X and Firewall
Hello Dudes !
Nowadays i'm working on my own lab at the office, before installing the equipment. My problem is the routing between the Catalyst 3750x and the Firewall Fortinet connected to my ISP (Service Provider/Internet).
I have briefly set on Catalyst 3750x :
Enable Routing :
     ip routing
Create Vlan:
     vlan 10
     name Data
     interface vlan 10
     ip address 192.168.10.254 255.255.255.0
Switch Port:
     switchport mode access
     switchport access vlan 10
     spanning-tree portfast
The Port (Giga 1/0/24) thats connect to my Fortinet
     no switchport
     ip address 192.168.100.1 255.255.255.0
Then add a default route to Fortinet Interface (Internal) Next Hop:
     ip route 0.0.0.0 0.0.0.0 192.168.100.2
On my Laptop:
     IP 192.168.10.10 / 255.255.255.0
     Gateway 192.168.10.254 (Interface VLAN 10)
     DNS Ex. 8.8.8.8
When I do ping to my Gateway 192.168.10.254 .. it Works !!
When I do ping to Catalyst Interface that connects to Fortinet 192.168.100.1 .. it Works !
But , when I do ping to Fortinet Interface .. Fail !!
The switch catalyst can ping fortinet interface 192.168.100.2 , and fortinet can ping
Catalyst port 192.168.100.1.
I was following this Guide
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Any ideas ?
kcnajaf
Level 7
Level 7
HI Julio,
Do you have a route back on fortigate for 192.168.10.x (VLAN 10) network ? If not please add that give a try.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
HI Julio,
Hope that helps.
Najaf
The solution was :
1.- Fortinet to LAN Switch 3750x = Static Route
2.- LAN Switch to Fortinet = Default Route
Thanks.
