routing ACL issue
nepalies_24
Hi All,
If anyone can help I will really appreciate. I could not figure out the problem myself
Basically, I have got router with 1 F0/0 and 4eth port. I have got 1f0/0 as WAN port configured and 4Eth port connected to different network. What I want to do is router traffic between 4eth connected hosts, so I can perform RDP and other stuff between eachother
Please check my config as follow
Current configuration : 6823 bytes
version 12.4
no service pad
hostname pirate
boot-start-marker
boot-end-marker
security passwords min-lengthx
no logging buffered
logging cns-events alerts
enable secret x
enable password x
aaa new-model
aaa session-id common
clock timezone GMT 20 28
clock summer-time London date Mar 30 2003 21:28 Oct 26 2003 22:28
no network-clock-participate slot 1
no network-clock-participate wic 0
--More--                           ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.xxxx 192.168.1.xxxx
ip dhcp excluded-address 10.10.10.xxxx 10.10.10.xxxx
ip dhcp excluded-address 192.168.10.xxxx 192.168.10.xxxx
ip dhcp excluded-address 10.10.20.xxxx 10.10.20.xxxx
ip dhcp pool xxxxx
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server
ip dhcp pool xxxxx
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server
ip dhcp pool xxxxx
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server
--More--
          ip dhcp pool Server
   import all
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.1
   dns-server
ip dhcp pool wirless
   import all
   network 10.10.5.0 255.255.255.0
   default-router 10.10.5.xxxx
ip flow-cache timeout active 1
no ip bootp server
ip domain name xxxxxx
ip name-server xxxxx
login block-for 80 attempts xxxxx within xxxxx
login quiet-mode access-class 10
login on-failure log every xxxxx
vpdn enable
vpdn-group xxxxx
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
--More--                           !
crypto pki trustpoint TP-self-signed-1020500782
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1020500782
revocation-check none
rsakeypair TP-self-signed-1020500782
username xxxxx privilege 15 password 7 xxxxx
username xxxx secret xxx.
username xxxxx privilege 15 password xxxx
username xxxxx view ITSUPPOT secretxxxx
username xxxxx  view Support secret xxxxx
username xxxxx privilege 15 secret xxxxx
ip ssh port xxxx rotary 1
ip ssh version 2
interface FastEthernet0/0
description WAN
ip address 10.10.5.78 255.255.255.0
ip helper-address 10.10.5.78
ip access-group route_virgn out
no ip redirects
no ip unreachables
--More--                            ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface Ethernet1/0
description Pulchok_pool exHdd
ip address 192.168.1.xxxx 255.255.255.0
ip nat inside
full-duplex
interface Ethernet1/1
description Server Pool
ip address 10.10.20.xxxx 255.255.255.0
no ip unreachables
ip nat inside
full-duplex
no cdp enable
interface Ethernet1/2
description Switch POOL
ip address 192.168.10.1 255.255.255.0
no ip unreachables
no ip proxy-arp
--More--
ip nat inside
shutdown
full-duplex
no cdp enable
interface Ethernet1/3
description JAPAN_POOL
ip address 10.10.10.1 255.255.255.0
no ip unreachables
no ip proxy-arp
ip nat inside
full-duplex
interface Virtual-Template1
description VPDN
ip unnumbered FastEthernet0/0
peer default ip address pool PPTP-Pool
ppp encrypt mppe 128
ppp authentication ms-chap-v2
interface Dialer0
no ip address
shutdown
ip local pool PPTP-Pool xxx.xxxx.1.xxx xxx.xxxx.1.xxx
no ip classless
--More--                           ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.5.1
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.10.10.xx 9996
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.10.10.xx 3389 interface FastEthernet0/0 3389
ip access-list extended xxx_drive
permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 10.10.5.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 10.10.5.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip any any
permit tcp any any
ip access-list extended route_xxxx
permit ip 10.10.10.0 0.0.0.255 10.10.5.0 0.0.0.255
permit ip 10.10.5.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 10.10.5.0 0.0.0.255
permit ip 10.10.5.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip any any
--More--                           !
logging trap debugging
logging 10.10.10.xx
access-list 10 permit 10.10.10.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 120 remark Internal 10 host
snmp-server ifindex persist
control-plane
banner motd ^C
NO UNAUTHORIZED ACCESS
***********************^C
no alias exec s
alias exec ipint sh ip int brief
line con 0
logging synchronous
line aux 0
line vty 0 3
exec-timeout 15 0
privilege level 15
logging synchronous
--More--                            rotary 1
transport input ssh
line vty 4
exec-timeout 15 0
privilege level 15
logging synchronous
rotary 1
transport input ssh
parser view xxxx
secret
commands exec include ping
commands exec include configure terminal
commands exec include show ip interface brief
commands exec include show running-config
parser view Ixxxx
secret
commands exec exclude configure terminal
commands exec include show ip nat translations
--More--                            commands exec include show
parser view xxxxx
secret
Richard Burts
You indicate that there is a problem but you do not tell us what the problem is. Without some understanding of what the problem is it is difficult to know where to start in looking at the config.
As a start I will observe that you have this access list configured on several interfaces:
but I do not see that access list in the config that you posted. Perhaps this is part of the problem?
If you can tell us some things that do work and some specific things that do not work we might be able to give better answers.
Rick
Rick
Hi Rick
Thank you for reply.
My problem is I can access host on 10.10.5.0 network from 10.10.10.0 network, but can't access any host from 10.10.5.0 network to 10.10.10.0 network AND also I can't access any host from 10.10.10.0 network to 10.10.20.0 network
ip access-group route_virgn out on int are for following access list
ip access-list extended route_virgn
permit ip any any
10.10.5.0 is my wireless network
Please add the below access into existing route_virgin ACL
ip access-list ext route_virgin
permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
Are you able to access from 10.10.5.x to 10.10.20.x? if no, please get us output of show ip access-list route_virgin (need to find if we are getting hits)
otherwise we need to check ACL 101 which is using for NAT.
Vignesh
