Beginner
Routing between two Interface VLAN on Cisco Catalyst 4507 Layer 3 Switch
Hi is possible routing between two Interfaces VLAN on the same cisco switch 4507 Layer 3
1 ACCEPTED SOLUTION
VIP Expert
Can you post your config and
Can you post your config and point out what port the pc is connected to?
You first need to create a vlan and than add the port that the pc is connected to to that vlan.
You also need to create an SVI for that vlan, give it an IP address and give the pc an IP in the same subnet as the svi
example:
config t
vlan 10
name test-vlan
exit
inter gi0/10 (PC in connected to this port)
switchport
switchport mode access
swtchport access vlan 10
exit
interface vlan 10
no sh
and give the PC IP 192.168.1.2
and test again.
make sure the interface where the pc is connected is up and up.
5 REPLIES 5
VIP Expert
Yes, if the switch is
Yes, if the switch is currently layer-2 only, you may have to turn on IP routing to route between vlans.
Beginner
Is a Layer 3 switch
Is a Layer 3 switch
VIP Expert
Than routing between vlans
Than routing between vlans should not be an issue.
Beginner
how, i try ping one PC
how, i try ping one PC connected to vlan no answer
VIP Expert
example:
config t
vlan 10
name test-vlan
exit
switchport
exit
interface vlan 10
no sh
and test again.
Content for Community-Ad
July's Community Spotlight Awards
