Routing between two subnets.
chinmoymohanty
I have two networks,Physicallyconnected .I.e;192.168.0.0 &192.168.1.0,How the communication possible between 2 networks.Where to configure routing.
amit-singh
Level 8
Level 8
Which device you are using? What's your setup. Explain and we will help you.
-amit singh
ferryfury
Hi Mohanthy,
what you need to is to have a layer 3 switch to do this.
hope this helps
rate this post if cleared.
Inorder to make two Subnet exchange information, we need a L3 Device.
It will be very helpful if you could share your setup
Regard
Danny
