01-23-2013 10:15 AM - edited 03-07-2019 11:16 AM
Hi everyone,
I was tracing the router when i did sh ip route it shows
sh ip route 192.168.210.16
Routing entry for 192.168.0.0/16, supernet ********
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 172.31.102.1
Route metric is 0, traffic share count is 1
Need to understand what does supernet mean here?
does it indicate bigger subnet mask?
Mahesh
Solved! Go to Solution.
01-23-2013 11:24 AM
Supernet is a nomenclature applied to a network witch is larger then should be allowed by the networks classfull boundary. In this case 192.168.X.X networks are Class C networks, the largest subnet you should be allowed to make of them is a /24 network. A /16 mask here is tying together 256 class C networks into one big supernet. Support for supernetting was introduced relatively recently.
01-23-2013 11:26 AM
Is the result of aggregating multiple subnets into one.
In your case, you are aggregating multiple Class C subnets into a larger address scope with the static IP route configuration implemented in the router.
01-23-2013 05:11 PM
Hi Mahesh,
The main benefit of aggregating multiple subnets into one is fewer routes in the routing table.
For examle, instead of seen 4 /24 subnets, you just see one /22 subnet.
Reza
01-24-2013 06:21 AM
There are plenty of benefits. One comes to mind is scalability, less prefixes in the routing table = less memory consumption.
01-24-2013 01:56 PM
Mahesh
The result of auto summarization is a single route (the "natural mask" network address - the class A or class B or class C network). aggregation is not necessarily going to produce a single route result.
I would suggest that aggregation and summarization are terms that mean the same thing. They both describe a process where we have a number of individual entries and we produce something with a smaller number of entries that include all of the addresses of the individual entries.
In addition to the benefits already given (smaller routing table, less memory) another possible benefit of aggregation/summarization is more stability in the routing table. Perhaps an example might help make clear what I mean. Think about a network that has 100 routers in it and that every router has 3 LAN subnets connected. If there is no aggregation/summarization then every router has a routing table with 300 entries. And assume that on one of the routers there is a problem with one of the subnets and the interface is flapping (it is up, and then it goes down, and soon it comes back up, but quickly it goes down again, and then it is up, and then down again, over and over). The result is that the other 99 routers are processing a routing update every time it goes down, and a routing update every time it comes up. So that is a LOT of routing updates.
Then think of that network and assume that each of the 100 routers does summarization of its LAN subnets and advertises one summary. Now the routing table of each router has 100 entries rather than 300. And now that subnet is flapping but there are no routing updates. The routing table is more stable because of the summarization.
Rick
01-23-2013 11:24 AM
01-23-2013 11:26 AM
01-23-2013 12:48 PM
Hi Edsion,
Thanks for answering the question.
Can you please tell me what is benefit of aggregating multiple subnets into one?
Mahesh
01-23-2013 05:11 PM
Hi Mahesh,
Reza
01-24-2013 06:21 AM
01-24-2013 08:09 AM
Hi Edison,
So we can say it is same as doing Auto summarization in EIGRP ?
When we do auto summ in EIGRP then also we have single route in routing table instead of many right?
Mahesh
01-24-2013 01:56 PM
Mahesh
Rick
01-25-2013 09:15 PM
Hi Rick,
Again your answer was pretty detailed and its hard to find the knowledge you have in books.
Best Regards
MAhesh
