Routing Issue
zekebashi
Level 4
Level 4
I built a very simply topology which I'll be building for a new project. Here's the summary:
Sw_02: Distribution Switch
                  SVI  VLAN100: 100.100.100.254/24 --- Used for for the default gateway for the server farm and workstation
                  F1/1 100.100.90.1/24      --- Used to connect Sw_02 to Sw_01
           F1/0: Trunk
           F1/2: Trunk
Windows Server2016: 100.100.100.99/24
PC1: 100.100.100.50/24
Ping results:
SW_02#ping 100.100.100.50
Sending 5, 100-byte ICMP Echos to 100.100.100.50, timeout is 2 seconds:
Success rate is 0 percent (0/5)
SW_02#
PC1> ping 100.100.100.254
host (100.100.100.254) not reachable
PC1>
Anything that I am missing here?
Thanks in advance,
~zK
2 Accepted Solutions
both server and PC are connected to the same switch, in the same VLAN, so if both ports on SW_02 are in the same VLAN, they should be able to connect, without any Layer 3 connection. Why are F1/1and F1/2 configured as trunks ? What happens if you simply make them access ports in VLAN 100 ?
If possible, post the configuration of SW_02.
Hello
As stated when there s only one vlan you dont have to have routing enabled as commutation would be all l2 unless you want the hosts to communicate to other vlans or off the vlan and out of your network.
Sw2
conf t
Int vlan 100
ip address 100.100.100.254 255.255.255.0
no shut
vlan 100
exit
ip route 0.0.0.0 0.0.0.0 <nexthop address>  off your LAN possibly pointing to your wan rtr.)
int x/x
description to Sw1
Switchport trunk encp dot 1
switchport mode trunk
int x/x
description to Sw3
ip routing
Sw1
int x/x
description to Sw2
no ip routing
Sw3
conf t
int x/x
description to Sw2
no ip routing
any of the switch(s)
int x/x/
description access ports for server or hosts
switchport host
switchport access vlan 100
no shut
Make sure all hosts have a default-gateway pointing to the svi on the vlan they are assigned to
res
Paul.
Kind Regards
Paul
Hello
Sw2
conf t
Int vlan 100
no shut
vlan 100
exit
int x/x
description to Sw1
int x/x
description to Sw3
ip routing
Sw1
int x/x
description to Sw2
no ip routing
Sw3
conf t
int x/x
description to Sw2
no ip routing
int x/x/
switchport host
no shut
res
Paul.
Kind Regards
Paul
pdriver  & gpauwen
I ended up making some changes on Sw_02 interfaces which are connected to the downstream devices. I changed one interface to an Access port and the other one to a Trunk port with the native vlan being the vlan the downstream device is a member of.
Thank you, both!
