Routing table going down
DaniloStanisic
After I put an access-list on one of my routers the routing table fails to update, this is the running-config of that router:
Building configuration...
Current configuration : 1059 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R5
ip dhcp excluded-address 8.0.0.0 8.0.0.15
ip dhcp excluded-address 8.0.0.18 8.0.0.24
ip dhcp pool dhcp_pool_r5
network 8.0.0.0 255.255.255.0
default-router 8.0.0.1
dns-server 8.0.0.3
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 8.0.25.2 255.255.255.0
ip access-group 101 in
duplex auto
speed auto
interface FastEthernet1/0
ip address 8.0.0.1 255.255.255.0
duplex auto
speed auto
router rip
version 2
network 8.0.0.0
ip classless
ip flow-export version 9
access-list 101 permit udp any host 8.0.0.3 eq domain
access-list 101 deny ip any host 8.0.0.3
access-list 101 permit tcp any host 8.0.0.2 eq www
access-list 101 permit icmp any host 8.0.0.2
access-list 101 deny ip any host 8.0.0.2
access-list 101 permit icmp any any
access-list 101 permit ospf any any
line con 0
line aux 0
line vty 0 4
login
end
and I should add that this is a router in an RIPv2 area, that connects to ASBR, so I think i have a problem with access-lists, after adding them the routing table becomes empty. Also in access-list I try to allow only DNS packages to my 8.0.0.3 server, and only HTTP and ICMP packages to 8.0.0.2 server, and also allow ICMP packages to any other host in the network 8.0.0.0/24.
What am I doing wrong here?
Giuseppe Larosa
Hello @DaniloStanisic ,
if the router runs RIP you need to permit this protocol RIP in access-list 101.
You have a line for OSPF but this router looks like to be configured only for RIP.
Be also aware that the order of the statements is very important.
Hope to help
Giuseppe
Hello, and thank you for you answer, but what excatly is the line im looking for to permit RIP protocol, because I don't seem to find it.
Edit:
So it wasn't under my udp list, but I put it down as a port number 520. And it worked.
Hi DaniloStanisic,
From the access-list we are missing the below statement:
"access-list 101 permit udp any eq rip any eq rip"
This will allow the RIP protocol so that you wont have any issue with it.
Hope this helps.
Naresh M
