Routing
wayne loh
Hi All,
Could anyone help me on the following question. As I know that the packet have to route from router to router via the destination MAC address of the gateway. However if I have the gateway(both end) that have different subnet(lan) interface that connect together and configure the routing. Will the packet reach from one end of the node to the other?
6 Replies 6
Same thing will happen
Yes that is what technically conceptual right. However, I could make both the end node to be communicate but somehow after sometimes of period it seems intermittently packet drop.
Is there any MetroEthernet or WAN links in-between ??
not it is LAN to LAN connection
can you run below ommand (as it is) on all in-between switches and routers:
sh int | inc Ethernet|drop|error|rate
Hi Wayne,
"if I have the gateway(both end) that have different subnet(lan) interface that connect together and configure the routing "
What do you mean by this..can you please explain more ..
Madhu
