routing
garytan231
hello guys, i want to ask do you think this configuration using rip is possible or not ? my teacher assign this as homework, as you can see vlan11 and vlan12 using the same ip is it possible or should i change the ip for vlan 12, thank you
Try use same IP and you will get messages from router or SW about overlapping
You need to use different IP
