RSPAN complicated
fewlcisco
Good day!
I'am using this configuration:
IP phone-----3560-------3750_kernel-------3750-1/2(stack)---->RSPAN destination port
                                       port-channel(SFP)
                                             STP pvst
If RSPAN destination port will be on 3750_kernel everything works well. But nothing if RSPAN destination port on 3750-1/2(stack).
3750-1/2(stack):
monitor session 2 source remote vlan 900
monitor session 2 destination interface Gi1/0/4
3560 and 3750_kernel:
monitor session 2 source vlan 7
monitor session 2 destination remote vlan 900
Any ideas?
5 Replies 5
Hi Dmitrity,
Assuming your RSPAN vlan is 900...
You need to do the following on 3560 and 3750_kernel
conf t
vlan 900
remote span
end
Smitesh
PS: Please rate helpful posts.
I wrote only importan commands. 900 vlan was created by VTP on all switches.
Important thing in above is
REMOTE SPAN
which should be given inside vlan mode.
Just to remove ambiguity, see below:
Switch(config)# vlan 900
Switch(config-vlan)# remote span
Switch(config-vlan)# end
If you have configure it same, then next thing to check is whether the RSPAN vlan is passed though all the switches...
Smitesh
RSPAN works on 3750_kernel... Trunk ports everywhere.
3750-1/2(stack) configuration:
Using 7820 out of 524288 bytes
! Last configuration change at 17:20:35 MSK Thu Feb 28 2013
! NVRAM config last updated at 17:27:15 MSK Thu Feb 28 2013
version 12.2
no service pad
service password-encryption
hostname C3750
boot-start-marker
boot-end-marker
enable password 7 072E234F1F5B4A
no aaa new-model
clock timezone MSK 4
switch 1 provision ws-c3750g-24ts-1u
switch 2 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp interface vlan30
ip subnet-zero
crypto pki trustpoint TP-self-signed-1447561216
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1447561216
revocation-check none
rsakeypair TP-self-signed-1447561216
crypto pki certificate chain TP-self-signed-1447561216
certificate self-signed 01 nvram:IOS-Self-Sig#3637.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport access vlan 31
interface Port-channel2
interface Port-channel3
switchport access vlan 32
interface Port-channel4
switchport mode access
interface Port-channel5
interface Port-channel6
switchport mode trunk
interface GigabitEthernet1/0/1
channel-protocol lacp
channel-group 5 mode active
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
channel-group 4 mode active
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
channel-group 3 mode active
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
switchport access vlan 201
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
switchport access vlan 9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
description ======= RSPAN port  =======
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
switchport access vlan 42
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
channel-group 6 mode active
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet2/0/1
switchport trunk allowed vlan 40,41
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
channel-group 2 mode active
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
channel-group 1 mode active
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
ip address 10.6.10.111 255.255.255.0
interface Vlan30
ip address 10.6.30.50 255.255.255.0
interface Vlan31
ip address 10.6.31.254 255.255.255.0
interface Vlan32
ip address 10.6.32.254 255.255.255.0
ip default-gateway 10.6.31.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.6.31.1
ip http server
ip http secure-server
logging trap debugging
logging facility local6
logging 10.6.32.4
control-plane
line con 0
exec-timeout 0 0
password 7 11281
login
line vty 0 4
exec-timeout 0 0
password 7 11281
login
line vty 5 15
exec-timeout 0 0
password 7 11281
login
monitor session 1 source vlan 8 , 31 - 32 , 40 - 43 , 200 - 201
monitor session 1 destination interface Gi1/0/14
monitor session 2 destination interface Gi1/0/15
ntp logging
ntp clock-period 36028705
ntp server 10.6.10.1 source Vlan1 prefer
end
Hi Dmitriy,
The command which I'm suggesting would be never seen in show running or show start, as it is specific to vlan command mode and hence would be save in vlan.dat.
Hence, if you not sure whether you have given those command or not; just put them in the following order on both the switches and then check.
Smitesh
