Rspan does not showing any logs
john smith
i have a HP speech log server (to recored ip telephony calls for monitoring) connected with my lan network
i have configured a layer 2 vlan (vloan 150) in core switch
and i its forward to other lan access switches through VTP domain
i have configured on core switch
vlan 150
name RSPAN-VLAN
Interface vlan 150
remote-span
monitor session 1 source vlan 150
monitor session 1 destination interface Gi3/1(interface connected to Monitoring server)
and in access switch
monitor session 1 source interface gi 1/0/1 , gi 1/0/2
monitor session 1 destination remote vlan 150
but its not working
but in server there are 2 NIC cards and one of them already connected with DMZ switch and configured static IP over that
through this NIC interface's static IP i can access to the server remotly and for GUI
my problem is that i have connected my core switch direct with server's 2nd NIC card's interface
so how i will configure core switch and server's 2nd NIC card in order to recieve logs
DMZ zone and switch zone are in diffrenet network addresses
let's say
DMZ is 172.16.0.2/24
Core is 10.1.0.1/24
and the voice vlan that i want to monitor traffic from is vlan 62 and have ip 10.1.62.0/24
thanks in advance
Eugene Khabarov
Level 7
Level 7
Network diagram will be helpful.
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
byronaustin
1:  If used as a RSPAN vlan, vlan(150) must be defined in the vtp server as a rspan vlan:
vlan 150
( vlan-config) remote-span
2: config for the destination session as such:
monitor session 1 source remote vlan 150
monitor session 1 destination interface g3/1  (monitoring box's interface)
3. config for the source session as such:
monitor session1 source interface g1/0/1,g1/0/2    (source of monitored traffic)
monitor session 1 destination remote  vlan 500
Make certain the rspan vlan is forwarded end to end.
In the  monitoring software should allow you to select the appropriate interface.
Please send a copy of the command output for
show vlan id 150
