how to safely turn off cisco router/switch?is it just turn off the power switch at the back of router/switchor need to issue soem command in user EXEC mode /privileged mode to shut down the router/switch? explain please, thank you
The content you are looking for has been archived. View related content below.
I accidentally bricked my Cisco C9300L switch and no longer has IOS or Bootstrap. Can I save copy of IOS and Bootstrap from my other Cisco C9300L switch and save to USB drive? Then copy images onto the switch that is inoperable?
hello every body what is the differentsfp-10/25g-lr-s (10-3251-01) and sfp-10/25g-lr-s (10-3251-02)
This is the standard template we are using for AP connected interfaces.interface GigabitEthernet 1/0/8descriptionXXXXXspanning-tree portfastswitchportswitchport mode accessswitchport access vlan 90logging event link-statuslogging event power-inline-...
We have 2 SG350x-48 switches in a stack. and we need to add another switch. but I know that SG350x-48 is no longer sold. what are my options? these were replaced by the "Cisco Business 350 Series Managed Switches". can one of these switches be a...
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
At Cisco Live I was able to get into a lab where the advisor showed a feature that I cannot find any information on how to implement or use. It was quick example. On the switch you can enable a packet trace and actually watch the packet traverse from...
Hi allI'm attempting to use 4 cisco SG350-28 switches connected around 100 meters apart. 3 switches will connect to 1 "central switch", each using a LAG (the far away switches are using SFP fiber modules). I have this setup and all seems to be workin...
Hi dears if i see advetise routes prefix to nieghbor X.X.X.X by details for example which community send wightand other bgp parameters How can see thisin bgp nexus switches for examples 9K series???
Hello, I have a 9300 switch that is on interface 11. This interface is connected to a windows machine and it looks like its packets are getting dropped. Is there a trace or some tool that can help me watch port 11 in real time? To see if the packets ...
Hoje temos um parque completamente formado por switches Cisco Catalyst série 2xxx, 3xxx e um core série 4xxx. Conseguiremos interconexão de um modelo CBS250 com um Catalyst usando trunk? O protocolo VTP irá funcionar?
Good morning friends,I have created two extended ACLs for in and out of my int vlan and applied it under int vlan for both directions inbound and outbound. I have created ACLs entries like this.For int vlan no. Out1 permit ip 10.1.0.0 0.0.255.255 hos...
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12. This is what I am struggling with, I currently have a vrf called AWSDX-S3. Now what I am trying to do is I have added a L2 SW and ran trunk ports...
We would like to purchase a cisco switch which need to be under TAA compliance. Please provide the TAA compliant statement (document), if the below mentionedCisco IB-C9300-48T-A and IB-C9300-24T-A is under Trade Agreements Act (TAA) compliance.
HiI have 4 Cisco 2960 switches and 3 unmanaged switches. All are connected via fiber cable to a core switch 4503-3 and it is connected to a VPN router and internet router. (still don't have access to the routers yet)I know I have to replace the unman...
Subject | Author | Posted |
04-24-2024 03:44 PM | ||
04-24-2024 02:27 PM | ||
04-24-2024 11:50 AM | ||
04-23-2024 09:53 AM | ||
04-23-2024 02:53 AM |
User | Count |
11 | |
10 | |
9 | |
8 | |
6 |
