Join Customer Connection to register!
330
Johnny Leon
Screws Dimension for Mouting a 3560-CX
Need exact dimensions for mounting screw, Cisco part # 48-2711-01-A0, to mount a 3560-CX compact switch.  Picture below:
Will be ordering 5000 of the screws.  Need help ASAP?
3 REPLIES 3
Reza Sharifi
Hall of Fame Expert
actually here is the correct kit part number and what is inside the box.
Cisco 48-1689-01-A0
Reza, is there any way to the know the dimensions of the screws?
Johnny,
The kit I have does not have the dimensions on it.  The screws are not long at all.  If I were to guess, it is about a 1/4 of an inch long.
