12-27-2010 10:33 AM - edited 03-06-2019 02:43 PM
I have a question regarding setting up our 3750X switch to handle both internet uplink and all end devices. My thoughts are as follows:
We currently have Internet -> L2 Switch -> (2) ASA Active/Passive -> L2 Switch (All Devices Plugin Here)
I would like to utilize our new 3750X switch to do Internet -> L3 Switch -> (2) ASA Active/Passive (BUT ALL devices plugin to L3 Switch)
New switch would have ip routing enabled and static default route.
Gi 0/1 could have L3 routing enabled with an IP Address to talk with the internet.
Here is where I am still a little confused. Do I need to utilize VLAN's in this situation to secure my internal servers/management since I am directly connected to the internet? Is my management at risk since it is still on VLAN 1 and the switch is now directly connected to the internet? How should I configure the ASA devices/switch ports so that they can talk to the internet and the internal network? Do I need to keep my default routes on my ASA devices or will the switch handle this. Is this a viable solution or should I keep a dedicated switch for the "DMZ" area where the Internet drop is. Any input would be greatly appreciated. Thanks Cisco Community!
-Rob
Solved! Go to Solution.
12-27-2010 12:32 PM
Hi Rob,
Since you want to use your new 3750 to connected to your service provider, you also need a layer-2 switch behind your firewalls to connect your users to.
So it would be Internet -> L3 Switch-3750X -> (2) ASA Active/Passive -> L2 Switch (All Devices Plugin Here).
On your L-2 switch, you just need a default route for the management vlan and default gateways for your users vlans would be the firewall. . Also, use any other vlan but vlan 1 for management, as vlan 1 is the native vlan and it is used for controll traffic. Depending on the number of devices you have, you also need to indentify 1 or 2 vlans/subnets for all your end user devices. You then need a layer-3 link between the fw and the 3750 with default route pointing towards the 3750.
Reza
12-27-2010 02:39 PM
Rob,
Even if it possible, I would stay away from designing it that way. You need to have a router/switch in front and behind the firewall to protect your resources and your network from the Internet.
Good Luck
Reza
12-27-2010 12:32 PM
Hi Rob,
Reza
12-27-2010 01:50 PM
Reza,
Thank you very much for the reply but just to clarify. The situation I described would not be possible correct? To have a single layer 3 device connecting external, internal, and firewalls. It sounded silly to me but I thought perhaps there was a way to configure it but after going through some mock environments I am hitting a lot of walls
12-27-2010 02:39 PM
Rob,
Good Luck
Reza
12-27-2010 03:00 PM
Thanks Reza. That is how I feel too. Thanks for you input it is valued greatly. Cheers!
