I am configuring my Cisco 3560 for a Mitel 3300 ICP. I have attached a copy of my config files on the switch. I am new to setting up the mittel 3330. The documentation state I should set up my switch with the following guidelines:To simplify the installation and
use some pre-packaged commands, such as auto-qos, a COS value of 5 is recommended
throughout the network. Other values, such as 6, can still be used, but will require additional
tuning of the configuration at different ports.
In order to make the QoS settings work, the following points need to be considered:
" QoS must be enabled for the entire switch.
" The default COS and DSCP settings of the switch may not be those needed for voice.
" Settings that are needed include:
- Change mapping COS 5 to DSCP of 46 (Expedited Forwarding (EF) setting).
- Ensure that COS 5 is mapped to the EF queue.
- Enable the EF queue.
- Trust incoming ports based on COS value for end points, phones, 3300 ICP and voice
servers.
- PC phones may require DSCP remapping as well as DSCP to COS conversion.
- Enable CDP.
" Auto-qos trust will change a number of these settings.
" Some additional tuning may be needed to the settings to get full operation
I want to ensure the settings are accurate on my switch. I have attached my configs
