SFP-10G-LR on Cisco WS-C3650-24PD-L
mlinder01
Beginner
Beginner
Dear All,
Right now we have the problem, that SFP-10G-LR are not working on Cisco 3650 10G Ports - IOS XE 3.3.0SE (see TE1/1/3 and picture in attachment). Which is really strange, becuase in the compatability matrix and in the datasheet this Module is supported. What is also strange is, that not orginial Cisco SFP+ LR Transceivers are working (see TE1/1/4)
*Mar 20 09:15:07: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/3 is not supported
*Mar 20 09:15:07: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/3, putting Te1/1/3 in err-disable state
Te1/1/3   to CSAARAWA01, Te1 err-disabled 1            auto   auto unknown
Te1/1/4   to GSAARKLBEG02, T notconnect   1            full    10G SFP-10GBase-LR
Has anyone made similiar experiences?
Many Thanks,
Manuel
What happens if you swap SFPs   between 1/1/4 and  1/1/3 are you getting the same error ? but at port 4 ?
Dear Dima L,
I will check this tomorrow... but expect the same error.
Manuel
Recognize Your Peers
