03-11-2013 08:59 AM - edited 03-07-2019 12:10 PM
Output for show int gig x/y shows the following output what type of module is installed ?
GigabitEthernet0/49 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0022.bd97.34b1 (bia 0022.bd97.34b1)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseCX SFP Cable ---------------> what type of module is this one?
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:23, output hang never
Pls. share the experience.
Subodh
03-11-2013 09:13 AM
Or is it a cable (patch chord) with SFP modules attached at the end. So we need to just plug these in the switch.
03-11-2013 09:30 AM
Hi ,
Please run the following command and this will show you the exact SFP part details.
show int G0/49 capabilities
* This output of this command will have the SFP model details.
Inayath
