ā06-01-2019 03:55 AM - edited ā06-01-2019 04:29 AM
Hello, i have double conected my switch sg350X from switch1.
In sg350X i have ports 1-10 in VLAN 1 and ports 11-20 in VLAN 2.
In ports 1 and 11 i have uplink from switch1. But here is problem: ports working only 1-10 but ports 11-20 in VLAN 2 doesnt work and in spanning tree i see port 11-uplink as backup....
Why its showing backup when it is in another VLAN...?
Help me pls with it i need working both ports...
Thanks.
ā06-01-2019 06:35 AM
how is these 2 links connected to uplink, and what is devices other side port 1 and port 11 ?
ā06-01-2019 07:22 AM
My case:
I have four floors and in every floor is switch connected to main rack by two utp.
In main rack i have router and switch.
I have two subnets - in main rack i have splited switch: GE1-GE12 -VLAN10 and GE13-GE24 -VLAN20
This two VLANs i have connected to router:
192.168.60.X - from router to GE1
192.168.70.X - from router to GE13
Its mean when i connect to GE2 i get IP from subnet 192.168.60.X.
When i connect to GE14 i get IP from subnet 192.168.70.X.
Its work perfect but i have probllem with switches in floors.
In floors i have splited switches as well main switch in main rack.
Its mean: For example first floor:
Switch is splitted GE1-GE12 -VLAN10 and GE13-GE24 -VLAN20
GE1 is connected to main switch to port GE2 (subnet: 192.168.60.X)
GE13 is connected to main switch to port GE14 (subnet: 192.168.70.X)
And here is probllem in floor switch work only GE1-GE12 (subnet 192.168.60.X) GE13-GE24 (subnet: 192.168.70.X) doesnt work - i dont get IP. And in spanning tree its showing GE13 as backup port WHY? when its different VLAN.
(Yes its work when i turn off spanning tree)
Need help pls.
ā06-01-2019 01:27 PM
I assume these ports configured differently - that is the reason spanning tree kick off make it as alternative link.
best suggest between main switch to floor switch make it as Port-channel ( so you have redundancy and allow VLAN 10 and 20 in that)
GE1 / GE 13 --- Port-channel ----- GE2 / GE14 ( allowed VLAN 10, 20)
Disable Spanning-tree not the best practice.
ā06-02-2019 12:10 AM
Thank you very much.
But as port chanel you mean LAG (link aggregation)....?
ā06-02-2019 01:40 AM
Yes please.
ā06-05-2019 05:26 AM
And btw. is it possible double connected switch in another vlan without blocking one of them port...?
ā06-05-2019 06:14 AM
what you mean double connected ? explain more ?
ā06-05-2019 08:32 AM
For example i have two same switches.
Both switches splited like:
GE1-GE12 VLAN1
GE13-GE24 VLAN2
Connected by UTP: From: SW1 GE1 to SW2 GE1 (from VLAN1 to VLAN1)
Connected by UTP: From: SW1 GE13 to SW2 GE13 (from VLAN2 to VLAN2)
I know i can use LAG and trunk for transfering this two VLAN but is it possible transfer by this double connection (one UTP transfering VLAN1) (seccond UTP transfering VLAN2)
Because when i connected like this its doesnt work. Only one VLAN work seccond its marked BACKUP.
Both VLANS are configured - all ports access untaged but i thing problem is when i double connect ports between switches SWITCH to TRUNK i dont know why its switching to TRUNK when i set acces...
ā06-05-2019 09:01 AM
