06-13-2022 09:14 PM
i want to configure a LAG für 2x10G LWL as shown on: (for bandwidth)
It is not running .........
Is there some thing i have to do on server side? I just connect the two SFP+ with LWL an did the change shown on the Link.
Server Windows 2022.
Thank you for an hint!
06-13-2022 10:56 PM
you need to do network teaming on server side. check below link
06-14-2022 12:06 AM
how is your server-side config, you need to configure Server-side also LACP, if not try Mode ON (removing LACP Option)
Troubleshoot steps :
make sure a single link comes up so you are sure Layer1 and 2 are ok, before you bundle the links.
06-16-2022 08:58 PM
Thank you! Now i need an Serviceslot. After Change has down i will write the result.
