SG500 InterVLAN Routing Issue
Roger1000
I would like to communicate between VLAN's on my switch configuration but unfortunately I can't do the following:
- ping between vlans (my default gateways on each host are correct)
- from a VLAN that is not the native VLAN 1 i can not access the internet router on port 1 but can from the native VLAN.
I noticed that via the CLI, I can see the routes created as ports are activated.  for example:
S  0.0.0.0/0          [1/1] via  192.168.1.1  0:13:10              vlan 1
C  192.168.1.0/24     is directly connected                        vlan 1
C  192.168.30.0/24    is directly connected                        vlan 30
C  192.168.40.0/24    is directly connected                        vlan 40
Unfortunately I can not see them in the Web UI for the switch.  I understand that they are supposed to be automatically updated in the UI.
also...Show arp output:
  VLAN    Interface     IP address        HW address          status
vlan 1     gi1/1/1    192.168.1.1     e0:5f:b9:0c:c6:d6   dynamic
vlan 1     gi1/1/9    192.168.1.4     f4:ce:46:fe:d7:0d   dynamic
vlan 1     gi1/1/10   192.168.1.91    f4:6d:04:41:e7:a6   dynamic
vlan 30    gi1/1/14   192.168.30.11   00:04:4b:17:34:a3   dynamic
vlan 40    gi1/1/8    192.168.40.92   00:d0:b7:6b:49:14   dynamic
Any suggestions on what setting to adjust to get this working?
Roger
16 Replies 16
You have most of it right.   The switch's port facing the router must have an ip address assigned that is in the same subnet as the router's ip address.   In your case,
1) switch port facing router = 10.10.0.2/24 on VLAN 1
2) router port facing switch = 10.10.0.1/24
Just change your default route (0.0.0.0 statement to point to the IP assigned to your switch's port facing the router, not the router's IP.  It should be:
ip route 0.0.0.0 0.0.0.0 10.10.10.2
Best wishes,
kpiq
One more thing... if your router is VLAN-unaware make sure that the VLAN assigned to the switch's "default gateway" port is untagged.   All traffic to and from VLAN-unaware devices must ingress/egress the VLAN-aware switch thru an untagged port.
