If my memory is correct the SG500 will act as a DHCP server by default?
I would just turn off the DHCP server on the SG500 and set a static address on your switch so you know where it is when you want to configure it.
You can then connect up your TP-Link and allow it to be the DHCP server for the network.
Hope that helps!
Matty
