SG95-16 Loopback Error Question
I have a SG95-16.  When using it to expand another switch, I get a blinking amber loop LED. No matter the port, no matter the cable tried, even tried a crossover .....results are the same. The port has two green LEDs for a brief moment, then the left LED blinks amber.
I have cascaded switches before with zero issues. What am I missing?
Mark Elsen
 - If at all possible , avoid the use of unmanaged switches on any network ; the problem seems to be related to spanning tree and those parameters can not be controlled on the SG95-16. You could check the logs on the parent switch to check what happened .
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
No logs to check. Even connecting the switch directly to an Xfinity router, the left lamps blinks amber. The switch is passing traffic. Using an older laptop with a 100Mb network card, I get downloads at 75Mb and uploads at 22 Mb, which is what I would expect.
Again, every port, any cable gives a loopback error. No other switch I have tried in the same configuration yields this error.
