01-07-2009 07:31 AM - edited 03-06-2019 03:17 AM
I understand the command. But is there a way to make the time so it doesnt take a minute to refresh to its neighbors?
R7(config)#do sho ip pim rp mapp
PIM Group-to-RP Mappings
This system is an RP-mapping agent (Loopback1)
Group(s) 224.0.0.0/4
RP 103.103.103.103 (?), v2v1
Info source: 103.103.103.103 (?), elected via Auto-RP
Uptime: 00:07:31, expires: 00:02:24
RP 99.99.99.8 (?), v2v1
Info source: 99.99.99.8 (?), via Auto-RP
Uptime: 00:07:04, expires: 00:02:54
Group(s) 236.1.1.1/32
RP 104.104.104.104 (?), v2v1
Info source: 104.104.104.104 (?), elected via Auto-RP
Uptime: 00:03:56, expires: 00:01:59
Group(s) 239.0.0.0/8
Uptime: 00:03:56, expires: 00:02:02
Solved! Go to Solution.
01-07-2009 09:50 AM
Michael,
The priority you are referring to is the BSR priority, not the RP priority.
RFC5059 defines 0 as the highest priority for the RP priority (the lower the better).
01-07-2009 07:41 AM
Michael,
Try configuring "no ip domain-lookup" in global configuration mode. This will stop the router from attempting to reverse lookup the addresses, which explains the longer response time.
01-07-2009 08:05 AM
Michael,
Sorry I misunderstood your question. I thought it was in relations to the time it takes sometimes to get the full output when you type this command.
01-07-2009 07:54 AM
Hi Mike,
With Auto-RP, there are two places to adjust the timer:
1) the RP by default will announce itself every 60 sec
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1014843
2) the mapping agent by default send out the discovery message every 60 sec
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1019374
Personally, I will make both timer to match.
HTH,
jerry
01-07-2009 08:17 AM
Ok after playing with multicast even more i have another question. According to ciscos site: (This is using BRS)
priority
(Optional) Integer from 0 to 255. The bootstrap router with the larger priority is preferred. If the priority values are the same, the router with the larger IP address is the bootstrap router. The default value is 0.
However it seems from the output of show ip mrouter that the higher lower RP is preferred. Or am i reading this wrong?
____SHOW IP RP MAPPING (104.104.104.104 pri higher)____
Info source: 99.99.99.7 (?), via bootstrap, priority 199, holdtime 150
Uptime: 00:31:17, expires: 00:02:23
Info source: 99.99.99.7 (?), via bootstrap, priority 200, holdtime 150
Uptime: 00:40:20, expires: 00:02:21
__SHOW IP MROUTE (104.104.104.104 pri higher)____
(*, 239.0.1.1), 00:11:21/00:00:35, RP 103.103.103.103, flags: SP
Incoming interface: FastEthernet1/4, RPF nbr 146.46.134.30
Outgoing interface list: Null
(*, 239.2.2.2), 00:17:19/00:02:56, RP 103.103.103.103, flags: SJCL
Loopback1, Forward/Sparse-Dense, 00:17:19/00:02:56
____SHOW IP RP MAPPING (104.104.104.104 pri lower)____
Uptime: 00:40:47, expires: 00:02:26
Info source: 99.99.99.7 (?), via bootstrap, priority 201, holdtime 150
Uptime: 00:31:44, expires: 00:02:23
__SHOW IP MROUTE (104.104.104.104 pri lower)____
(*, 239.0.1.1), 00:00:23/00:03:06, RP 104.104.104.104, flags: S
Incoming interface: Null, RPF nbr 0.0.0.0
FastEthernet1/4, Forward/Sparse-Dense, 00:00:23/00:03:06
(*, 239.2.2.2), 00:18:55/00:02:35, RP 104.104.104.104, flags: SJCL
Loopback1, Forward/Sparse-Dense, 00:18:55/00:02:35
01-07-2009 09:50 AM
Michael,
01-07-2009 09:57 AM
ahhhh its great when things just make sence :).
Thanks alow
