09-23-2013 12:59 PM - edited 03-07-2019 03:38 PM
Forgive me, if this is an easy one, but can someone tell me how to see all the active Vlans for a vpc?
I do a sho vpc or show vpc 30 and they both cut off the active vlans. I have adjusted the terminal width, as well.
NAHIMIUS0102DCENT02-L3# terminal width 200
NAHIMIUS0102DCENT02-L3# sho vpc 70
vPC status
id Port Status Consistency Reason Active vlans
70 Po70 up success success 1-2,111-114
,129,140-14
3,148-153,1
55-159,166-
176,180-183 ....
I know there are more vlans, but can't seem to see them, same thing happens, when I do a show vpc.
Also, it's Nexus 7018 & running 6.0(4).
Thanks for any insite!
09-23-2013 05:02 PM
sh vpc consistency-parameters vpc <#> will give you full output of the allowed vpc vlans amongst other details.
09-23-2013 09:12 PM
Jason,
Easy one just check the following things:
1- Show vlan { Kindly check how many vlans are been configured)
2- Show VPC / Show vpc brief will show you with all the Active Vlans. (NOTE: Check if there is any manualy config of vlan allowed been configured on the port-channel if yes then make sure all the vlans are been allowed on the port-channel).
Inayath
*Plz rate if this info is helpfull.
