Simple network including IR829 and Catalyst 3560
bas123
Beginner
Beginner
Hello
Create a simple network as shown in the figure.
Need config for IR829 and Catalyst 3560 (be specific to these devices), so that a PC as end user be able to ping to the router.
Giuseppe Larosa
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Hello bas123,
a) IR829
it uses SVI interface Vlans as Layer 3 interfaces
config t
vlan 10
name data10
exit
vlan 20
name data20
exit
int gi1
switchport
swithcport mode access
switchport access vlan 10
desc to switch fas0/1
int gi2
switchport
switchport mode access
swithcport access vlan 20
ip routing
int vlan 10
ip address 192.168.10.1 255.255.255.0
no shut
int vlan 20
ip address 192.168.20.1 255.255.255.0
no auto-state
! above to make SVI Vlan20 to stay up even if gi2 is not connected
Note: the switchport command may be not needed or even not accepted on IR829 in case go on to put the following commands.
b) SW 3560
vlan 10
name data10
vlan 20
name data20
exit
int fas0/1
switchport
desc to IR829:gi1
int fas0/2
desc to PC
switchport
c) PC
ip address 192.168.10.250 255.255.255.0  DEF GW 192.168.10.1
remember to save configurations on router and switch with
wr mem
or
copy running-config startup-config
Hope to help
Giuseppe
Giuseppe Larosa
Hall of Fame Master
Hello bas123,
a) IR829
config t
vlan 10
name data10
exit
vlan 20
name data20
exit
int gi1
switchport
int gi2
switchport
ip routing
int vlan 10
no shut
int vlan 20
no auto-state
b) SW 3560
vlan 10
name data10
vlan 20
name data20
exit
int fas0/1
switchport
desc to IR829:gi1
int fas0/2
desc to PC
switchport
c) PC
wr mem
or
Hope to help
Giuseppe
Thanks a lot
Cheers
Recognize Your Peers
