Simple OSPF configuration, but not work as I imagined
berniechen
I try to set up a very simple OSPF configuration.  Cause I do not have Cisco router, it is tested by qugga in VM.
RTA(192.168.0.1) <------->(192.168.0.2) RTB (192.168.2.2)<--------> (192.168.2.3)RTC
All of interfaces belong back-bone area.
When I ping 192.168,2,2 from RTA, it is OK. Then I ping 192.168.2.3, it fails. I paste running-config below. It is quite simple. Can anyone tell me what is wrong with it. It is a quagga's issue, configuration issue or it just work as OSPF designed?
BTW, I try to set 192.168.0.0/24 to area 0.0.0.1, but nothing changes.
RTA
Current configuration:
hostname ospfd
password zebra
log stdout
interface eth0
interface lo
router ospf
network 192.168.0.0/24 area 0.0.0.0
line vty
end
RTB
hostname ospfd
password zebra
log stdout
interface eth1
interface eth2
interface lo
router ospf
network 192.168.2.0/24 area 0.0.0.0
line vty
end
RTC
hostname ospfd
password zebra
log stdout
interface eth3
interface lo
router ospf
line vty
end
16 Replies 16
viswamin
can you check if the neighborship is established betwee RTB and RTC?
or pass on the output of the following commands
sh ip ospf int br
sh ip ospf nei
sh ip ospf database
-Vijay
I believe the neighborship has been established. Cause I can ping 192.168.0.2 from RTC
Anyway I paste more information below as you requested. Thanks in advance
RTA
ospfd# show ip ospf interface
eth0 is up
  ifindex 2, MTU 1500 bytes, BW 0 Kbit
  Internet Address 192.168.0.1/24, Broadcast 192.168.0.255, Area 0.0.0.0
  MTU mismatch detection:enabled
  Router ID 192.168.0.1, Network Type BROADCAST, Cost: 10
  Transmit Delay is 1 sec, State Backup, Priority 1
  Designated Router (ID) 192.168.2.2, Interface Address 192.168.0.2
  Backup Designated Router (ID) 192.168.0.1, Interface Address 192.168.0.1
  Multicast group memberships: OSPFAllRouters OSPFDesignatedRouters
  Timer intervals configured, Hello 10s, Dead 40s, Wait 40s, Retransmit 5
    Hello due in 4.235s
  Neighbor Count is 1, Adjacent neighbor count is 1
lo is up
  ifindex 1, MTU 16436 bytes, BW 0 Kbit
  OSPF not enabled on this interface
ospfd# show ip ospf database
       OSPF Router with ID (192.168.0.1)
                Router Link States (Area 0.0.0.0)
Link ID         ADV Router      Age  Seq#       CkSum  Link count
192.168.0.1     192.168.0.1      222 0x80000004 0x7923 1
192.168.2.2     192.168.2.2      209 0x80000005 0x2c74 2
192.168.2.3     192.168.2.3      205 0x80000002 0x810f 1
                Net Link States (Area 0.0.0.0)
192.168.0.2     192.168.2.2      228 0x80000001 0x9019
192.168.2.2     192.168.2.2      209 0x80000001 0xa4fe
ospfd# show ip ospf ne
ospfd# show ip ospf neighbor
    Neighbor ID Pri State           Dead Time Address         Interface            RXmtL RqstL DBsmL
192.168.2.2       1 Full/DR           36.240s 192.168.0.2     eth0:192.168.0.1         0     0     0
RTB
eth1 is up
  Internet Address 192.168.0.2/24, Broadcast 192.168.0.255, Area 0.0.0.0
  Router ID 192.168.2.2, Network Type BROADCAST, Cost: 10
  Transmit Delay is 1 sec, State DR, Priority 1
    Hello due in 8.473s
eth2 is up
  ifindex 3, MTU 1500 bytes, BW 0 Kbit
  Internet Address 192.168.2.2/24, Broadcast 192.168.2.255, Area 0.0.0.0
  Designated Router (ID) 192.168.2.2, Interface Address 192.168.2.2
  Backup Designated Router (ID) 192.168.2.3, Interface Address 192.168.2.3
    Hello due in 7.923s
lo is up
       OSPF Router with ID (192.168.2.2)
192.168.0.1     192.168.0.1      259 0x80000004 0x7923 1
192.168.2.2     192.168.2.2      243 0x80000005 0x2c74 2
192.168.2.3     192.168.2.3      239 0x80000002 0x810f 1
192.168.0.2     192.168.2.2      263 0x80000001 0x9019
192.168.2.2     192.168.2.2      243 0x80000001 0xa4fe
192.168.0.1       1 Full/Backup       39.540s 192.168.0.1     eth1:192.168.0.2         0     0     0
192.168.2.3       1 Full/Backup       39.341s 192.168.2.3     eth2:192.168.2.2         0     0     0
RTC
eth3 is up
  Internet Address 192.168.2.3/24, Broadcast 192.168.2.255, Area 0.0.0.0
  Router ID 192.168.2.3, Network Type BROADCAST, Cost: 10
    Hello due in 0.732s
eth4 is down
eth5 is down
  ifindex 4, MTU 1500 bytes, BW 0 Kbit
lo is up
       OSPF Router with ID (192.168.2.3)
192.168.0.1     192.168.0.1      156 0x80000004 0x7923 1
192.168.2.2     192.168.2.2      141 0x80000005 0x2c74 2
192.168.2.3     192.168.2.3      135 0x80000002 0x810f 1
192.168.0.2     192.168.2.2      160 0x80000001 0x9019
192.168.2.2     192.168.2.2      141 0x80000001 0xa4fe
192.168.2.2       1 Full/DR           36.222s 192.168.2.2     eth3:192.168.2.3         0     0     0
Hi ,
You should check the routing table of the systems.
RTC : route -n
RTB : route -n
RTA : route -n
Dan
Hi Dan
I think the routing table in RTB is wrong. I also capture the ping packet, when I ping 192.168.2.3 from RTA, the ping request packet only can be catched in ETH1 RTB. But why? Did I miss anything for OSPF configration.
RTA
:~# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.2.0     192.168.0.2     255.255.255.0   UG    20     0        0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 eth0
RTB
:~# route -n
192.168.2.0     0.0.0.0         255.255.255.0   U     1      0        0 eth2
192.168.0.0     0.0.0.0         255.255.255.0   U     0      0        0 eth1
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 eth1
0.0.0.0         192.168.2.2     0.0.0.0         UG    0      0        0 eth2
RTC
:~# route -n
192.168.2.0     0.0.0.0         255.255.255.0   U     0      0        0 eth3
192.168.0.0     192.168.2.2     255.255.255.0   UG    20     0        0 eth3
ebarticel
Level 4
Level 4
Why you have so many zeros after area? Also you don't have a process ID for OSPF.
When you configure network statement, area has only one 0.
Example:
router ospf 1
network 192.168.0.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
That should fix your OSPF routing
Eugen
Hi Eugen
Thanks for your suggestion, it does not work. And I personally dun think there is any difference between 0.0.0.0 and 0
And I am not sure whta is process ID, is it router ID? If yes, quagga will assiagn the router ID automatically.
Chen Xi
Area ID si different from process ID.
Area ID has a 32 bit lenght.
So area 0 is area 0.0.0.0 , area 1 is area 0.0.0.1 ... and so on
Dan
It seams ok.RTB has 2 connected networks and RTC and RTA have 1 connected and 1 routed each
Do you have any filtering on any of the systems ?
iptables -L -nxv
Also can you check from RTB that you can ping both RTA and RTB.
Dan
I don't know much about Quadda, but I have another suggestion.
If this is a software solution why don't you set OSPF priority to 0 on RTA and RTC and have just RTB as DR, without BDR.
Maybe it will help.
Eugen
Hi Eugen,
this is a Quagga config not an IOS config so no need for the pid and concerning the area number this is a 32 bits value which can be expressed in decimal or dotted decimal notation so 0.0.0.0 is perfectly valid.
Regards.
Alain
Hi Alain,
Even with IOS , the 32bit area id is valid.
Dan
Hi Dan,
I know but  I didn't say the contrary, did I ?
Regards.
Alain.
Not explicitly
Dan
Thanks Alain. I never heard of Quagga config. What is that?
Eugen
