Single Mode Fibre connectivity thru GLC-SX-MM= works or not ?
sivakumar.kvp
We have two buildings beyond 200 metres.We have got single mode fibre running between the buildings but we have GLC-SX-MM= SFP module in hands.CAn we do the connectivity ?If works,is it a standard pratise ?
Collin Clark
Here is a link that shows where you can mix MM with SM and if a conditioning patch cord is needed (refer to Table 6).
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
Hope that helps.
Giuseppe Larosa
Hello Sivakumar,
it doesn't work :
SM fiber acts as a narrower filter and will drop most of optical energy of the MM transmitter.
You need SM GBICs or SFPs to use SM fiber
Hope to help
Giuseppe
Thanks for your reply.
thanks siva
