Single NIM-ES2-8 in ISR 4431
solid_978
We are looking at deploying ISR 4431 routers to replace some older 1811's.
If I have understood as well, The module evidenced "1xNIM-ES2-8 and NIM-ES2-8-P" should act like a two switch inside the ISR; numered with syntax interfaces like VSS, namely something like INTERFACE X/Y/Z.
Now the question is who I am not to able to recover in some CISCO web site:
how many SVI (sWITCHED VIRTUAL INTERFACE) or BVI (BRIDGED VIRTUAL INTERFACE) can I associate on NIM-ES2-8?
For example can I to map 2 or 3 interface, every kind, LAYER 3 on same module or NIM -ES2-8 is just Layer 2 and I cannot apply none SVI?
I found that I can create a SVI for Intrachassis Cascading, but I do not know if I can create SVI or BVI on same and alone NIM?
Any help would be appreciate!!!
Thanks to all.
Reza Sharifi
Does the latest ISR4000 code allow for Etherchannel support yet? Is it on the horizon for the NIM-ES2-4 and -8 Modules?
Bob
lsharrah
configure one of your switch ports as an access port for vlanxxx, then configure an SVI interface vlanxxx.
interface g0/1/0
switchport mode access
switchport access vlan100
interface vlan100
ip address 10.1.1.1 255.255.255.0
