03-17-2013 10:31 PM - edited 03-07-2019 12:18 PM
I am getting very slow window file transfer speed (4 Mbps per second) between two connecting servers in Cisco 6509 switch. I have connect the two laptops in 6509 switch in same module using the same vlan and try to copy the files from one laptop to another and vice versa and got the same speed on 4 to 5 Mbps per second.
Switch utilization is not more than 10% and both the laptops are connected in 1 Gbps full duplex.
I have checked by removing the gateway in both laptop but the output is same.
Please suggest how to resolve this.
03-17-2013 11:01 PM
Hi Jayesh,
Have you manually configured the speed to 1Gbps on both Laptop and Switch end? Or is auto negotiated? If it is autonegotiated try to set the speed and duplex manually on both switch and laptops ends and verify if that improves the transfer rates?
Najaf
Please rate when applicable or helpful !!!
03-17-2013 11:33 PM
Thansk for the response...
I have checked both the way by auto negotiation and by manuall configured port speed, but the result is same.
03-17-2013 11:40 PM
Hi Jayesh,
Hmmm....
What type of file are you trying to transfer? Is this a windows copy/past which you are trying to do? If so can you try with some external copy tool like TeraCopy rahter than native windows copy tool?
Najaf
03-17-2013 11:42 PM
Hi Jayesh,
Can you please change the ports between two ends and check.
1- Check the cable if possilbe change it.
2- Speed and duplex to be same
3- Check changin the vlan to see wheather only specific vlan or all the vlans has the issue.
4- I am assuming tht you have already check the cpu at both the ends and its is low.
5- Can you paste the configuration of both the ports?
6- If possbile have these laptop connected between different modules.
7- How about ping packets? Does those go fine without any much delay?
Inayath
03-18-2013 10:06 PM
Actually we are getting slow file copy speed in two servers of same range connected in the same module of switch.
To check the speed i have connected two laptops in the same module where server is connected, using standard company made patch cord and check the file copy speed. I am getting the same 4 mbps speed per second which i get in the servers.
I check the same buy connecting the two laptops in different module, conecting one laptop in one and other in second module but the result is same. I have check the same by manually configured switch port as a 1 gbps and full duplex and also by auto but not getting the desired output.
Ping packets are of 1 ms continuously.
Port configuration:
interface GigabitEthernet7/23
switchport
switchport access vlan 102
switchport mode access
end
Switch#show run int gi 7/24
Building configuration...
Current configuration : 101 bytes
interface GigabitEthernet7/24
switchport
end
03-18-2013 10:22 PM
Hi Jayesh,
Could you please provide the output of "show interface status" & "show interface gix/x" and highlight where the two servers are conencted?
Also your interface configuration does not show the speed and duplex has been manually set.
It should have been
speed 1000
duplex full
Also could you please connect the laptops back to back using cross cable and try to do the file transfer and see how much speed your getting?
I'm affriad to say that previously when i tried this (back to back) with gig interface the maximum i could get was 8Mbps 😞
Najaf
03-18-2013 11:24 PM
Also you can try next step:
1. create new vlan for you test laptops.
2. put 2 ports in new vlan and connect laptops
3. test speed.
If you have same slow speed, download iperf and try testing. For example you use
http://openmaniak.com/iperf.php guide
If you get good results, you need check traffic(TCPWindos size or many broadcast in vlan). Also you can span traffic from one of interface and analyze it, Maybe you have small TCP window size
